I can see it starting right now. 20 questions and pulling hens teeth.
Please supply the following info
1. Line phases and voltage
2. Nameplate on drive or adequate description of rated line voltage and current. Rated motor type volts and amps
3. Nameplate info on motor OR type of motor as I asked for in #3. Include rated voltage and current, HP and RPM. Sure would be nice to include rated torque
4. Take torque wrench and measure torque at the input of the conveyer ideally the gearbox input shaft.
Dan Bentler
1. 240volts single phase
2 minnark drive 240/120 vac 90/180 vdc 5 hp
3 180 vdc 5 hp 1750 rpm 24.5 fla
4 I had the motor unloaded so I wouldn't think torque would be a factor
Thanks again for everyone's involvement
