DataMan DM280 and CompactLogix 5380
Pilionis
Jul 2023
Galway
:sick:
Hi, I am looking for a little bit of help :
I have Cognex DM 280 barcode reader connected through ethernet to CompactLogix 5380 and managed to add the device when it scans I can see some numbers, but how determine what is what, each of my codes represents color? I was looking for Cognex DM280 add-on instructions for Allen-Bradley, but can't find anything.
Has anyone experienced this before and know what is the best approach?
Paul
I've used DM260 AOI/EDS instead and it works.
This is a workaround that Cognex suggested, they were not sure if they will ever release anything similar for 280 model.
:sick:
Paul
Hi, how did you make it work ? I am not getting EDS for DM280.
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
101
Has anyone every attempted to run a Dataman Scanner through a 1783-NATR to take a local network to your enterprise network? I have the NAT...
18
3,048
Hey guys, I have an older Cognex Dataman scanner that i have added to a machine. I have established comms over ethernet. I am able to trigger...
1,797
I am planning on working with a cognex scanner 370 series using a beckhoff PLC and Ethernet/IP protocol. My question is does anyone know if the...
1,266
Hello all.. I am presently working with a Cognex Dataman dm8700dx-e (ethernet) scanner and need to make it communicate (read data from) with a AB...
3,284
