CX-Programmer Data Monitor
Monitoring any memory area in the PLC. You can monitor in HEX, integer, floating point - whatever you want.
Thanks Bob. It pops up when it wants to and it doesn't display anything of value and though it looks resizeable I could not resize it. And after reading your reply I went back to look for it and can't find a way to make it appear.
There is a memory button in the workspace - double click and it will pop up for you. I use it all the time when doing Modbus reads into DM areas and that sort of thing. Also when I have a lot of analogues it is really handy.
Thanks Bob. I'm not sure we're talking about the same window. I am referring to the little window I circled in red. IS that also a memory window? I am starting to think it's a CX bug as I can not get it to popup again.
bonjour je souhaiterais savoir si c'est possible de faire communiquer Cx-programmer ( logiciel de programmation des automates Omron ) avec...
165
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
167
I need a good website or tutorial to learn plc programming Thank you
519
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
392
Dear all, First of all thanks for letting me join this forum. I just need some help in one of my programming exercises. Being a beginner...
623
