Conveyor PLC
Nadda
Apr 2024
Galle
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor stops because of the safety switch or sensor, it can start the safety recovery switch only. What is the PLC diagram?
Is this a homework assignment? If so the community is happy to assist but we generally just provide some guidance and not direct answers.
If not are you asking what the electrical diagram may look like in order to assist in troubleshooting? Can you provide any details to the interlock system, for example relays or lights/alarms you are seeing?
There is a conveyor and there are three ways to stop it. One has a light curtain, if you pass through it, there is a safety emergency stop button, and if there is a jam in the middle of the conveyor, there is a sensor to detect it. If it stops due to safety, it can be started only with the emergency start switch itself. If it stops due to a jam, it will start automatically after the jam is gone. Where do you write a ladder for this?
there are too many unknowns to answer.
if this is not home work,
which plc, is there an hmi?
what is the components you are required to use?
what light curtain is being used?
what safety relay is being used?
are there e-stop pull cords?
low many conveyor motors?
what is the conveyor layout and how is it configured.
to write the program, you must first write out what you want the system to do.
then what i/o to add.
then use the plc software to write the code.
as i said, lots of unknowns.
james
The emergency stop must be independent of the PLC, it must be a wired circuit, unless a safety PLC is used, which I do not think is the case for you.
Normally a specific safety relay is used, which is manufactured by many brands and on its specifications you will be able to see the connection diagrams to connect the safety barrier and the emergency buttons
Hi everyone, Im not after someone to do my task, I'm just after some guidance or even pointed to some online resources I may use to learn more. I...
29
8,219
Need help with designing and test a PLC-controlled pneumatic system that conveys manufactured parts and loads them on a packing machine. I am...
2,675
Hi, I need help in designing a control system for conveyor. The goal is to connect PLC to bar code sensor and then connect plc to serve to...
1,296
Hey I am having issues witb this project im working on and I seem to have trouble on how to approach the objective can someone assist me please
18
3,213
Good Morning Everyone, I am entry level PLC programmer and this is going to be my first PLC project at my company. I would like to thank you for...
4,265
