Converting MicroLogix 1400 to S7-1200
iMalinko
Mar 2016
Massachusetts
Hi, all.
I am not so familiar with Allen Bradley PLCs. I currently have a (working) MicroLogix 1400 PLC program that I need to convert to S7-1200. I am familiar with the Siemens side of things. Is there some sort of guide / guidelines / advice, or something of use that can help me translate the program? Any recommendations would be appreciated!
Hi, all.
Siemens does have some code conversion services. They don't specifically list support for ML1400, but the converter might happen to support some of it as well. I doubt it takes the code and automatcally implements S7 best practices, but at the least, you might get some basic logic.
http://www.industry.usa.siemens.com...resources/pages/code-conversion-services.aspx
We have a simple pallet wrapper that we are trying to convert from a S7-200 to a MicroLogix 1400. Out of 119 rungs we're getting stuck on...
1,819
I'm changing my micrologix out 1100 out for slc505. I'm not understanding how to change my osr to ons, or even if that is correct. My osr is in a...
1,341
I am using an AB Micrologix 1200 that contains a counter with a destination of a floating point number. The number can get very large so I need...
8,417
I have a RS Logix 500 Micrologix Program that I would like to convert over to a RS Logix 5000 Contrologix Program. Can I do this ,and what is the...
5,473
Can you write and test software on a Micrologix PLC and then convert it to run on a PLC5?
5,791
