Communication PLC and sensor using RS 485
rajesh_gklm
May 2009
Bangalore
I am a beginner!!
I have a sensor which have only RS 485 port having three terminals 485+,485- and Ground. I want to communicate that with EZ touch PLC which have RS 422/485 port which contain RD-,RD+,SD-,SD+ and GND. I just jumpered RD- & SD- and SD+ & RD+. Connected RD- with 485- in sensor and connected and SD+ with 485 + of sensor. Ground of sensor is connected to the ground of PLC. But it is not communicating. I have sent data through RS 485 port through software. How would i know that data is sent through the port??
Please help me
Thank You
What is your sensor - brand/model? Give us as much information as you can -- don't make us guess...
another note one is full duplex one is half duplex the half duplex is the two wire setup the other is full duplex 4 wire or in other words has handshaking. the 4 wire setup may or may not be able to use half duplex but most likely it can and transmit goes to recieve so rd- to td- td- to rd- unless your using the null modem setup unlikely in your case. your going to have to find out which is the transmit the 485+ or the 485 - (very unusual nomenclature for a device what is it?)
Dear All, I am facing problem in modbus communication between Siemens PLC S7-1200 and CO detector sensor (Make: Grey stone). I have ensured the...
6,866
200
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
192
Hello We have installed several G.E. Fanuc 90 70 PLC Everything was ok but suddenly we can not communicate anymore with any PLC with the software...
100
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
118
