Cognex to Siemens via TCP Connection
wvos
Oct 2011
veghel
Hiya,
Im triggering a cognex camera by a sensor and from then on i want my In-Sight Explorer program to do something and have an output string with information i want to send to a DB in my Step 7 Program, over a TCP connection.
I tested this with a tcpscript program. I managed to send a string to the tcpscript program from my In-Sight Explorer program.
I also managed to send a String from my tcpscript program to a DB in my Step 7 Program.
So im missing one final link. Whenever i connect my netpro and set it as a passive connection ( So In-Sight Explorer initialises a connection over a certain port ) it wont establish this connection.
Does anybody know if there is something wrong with my system or do cognex and siemens simply communicate through a different TCP/IP protocol? Is Cognex even able to communicate to a CP443-1 IT card using a TCP connection?
Which signals do I have to use to get data from camera. For example camera detects a defect and sends signal to controller. Power cable: CCB-PWRIO-05
241
Hi everyone i want to ask if i can connect Congnex Emulator to Siemens Tia portal? but without Cognex Camera.
529
I have an in-sight cognex camera connected via profinet, and it is up and running perfectly. However, for reasons too long to explain, I need to...
6,299
I am having some issues in the profinet functionallity, when I put the camera in offline mode from the insight software it puts my processor in...
3,809
I've got a Cognex In-sight camera setup with OPC to WinCC Flexible RT. Works good without any trouble however I don't have a way to display the...
11,583
