Changing the background on a HMI
Greg7683
Jun 2018
Plainfield IN
355
Is there a way to add your own picture on the background of the screen that will allow you to add buttons to it. I placed a picture over the background of window 10 and added buttons to it but the picture and buttons don't show when I run it.Weintek HMI
I think you should really spend some time work with all of the example "Weintek/Maple Systems" offer. They have some very good examples for a lot of the questions you have asked on this forum.
Greg, if you add an image and then send it to the bottom layer it should be visible at run time, with the buttons visible over the top.
Not sure why a picture wouldn't show, you haven't got any odd security settings assigned to it by mistake have you?
Greg, here is one I've just mocked up and ran in offline mode.
Btw, if you want to ask questions outside of this forum just message me and I'll give you my email. I may not have all the answers regarding Weintek, but I've been using them for 2 years or so now.
Hmm bottom layer 8 have to look for that and no security settings I add2d it to my library and used it from there didn't work out that well will try the bottom layer thing
Thanks that worked but maybe you can help me understand this I made 3 screens added text to them all the words are aligned on the screens but when I do the off line sim and put it on the HMI the words aren't in strait lines any more how can I keep them aligned.
Odd, are all the text boxes set up the same in terms of formatting? For example text aligned left etc., and the text boxes all set in the same position from the left?
I finally figured it out for some reason it had big spaces befor the numbers As I was back spacing it jumped like a half inch I had to clear that space.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
266
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
506
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
102
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
306
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
227
