Backplane Data Transfer Speed of CompactLogix 1769 Series?
skyfox
Nov 2006
CA
279
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact.
Cheers.
For embedded modules across backplane, I/O is serviced by the RPI rates set in the configuration. Minimum for each module is 1ms. However, it depends on number of modules and whether there are any specialty modules. As the number of modules increases, you have to increase the RPI or you may fault with overruns. Rockwells guideline is 2ms for 1 to 2 digital modules, 4ms for 3 to 4 digital, and 8ms for 5 to 6 digital. Analog and specialty add 20ms per module.
Hey guys, I'm hoping for some help here. Normally my machines are small enough that one L62 can handle the load with average cycle times around...
2,764
I noticed something that’s mostly just a curiosity. Maybe someone here knows. An IT system is reading a L82 with the on-board IP and 1,0 added...
712
Hi everyone, I can't add any modules to the Controllogix backplane and it doesn't matter online or offline. Both is not working. Please see the...
3,023
Good Evening, I've spent most of the evening working on adding a 1768-ENBT card to connect a machine to our enterprise network. The card is...
1,510
Anyone ever vinyl wrap a backplane, and is it acceptable to do so? We are building a panel for 15 VFD's, and thought about using a vinyl wrap to...
2,984
