Automation Direct CM5 HMI Review
If you have an existing project with a EA9 Cmore, you cannot directly import objects from that project into a CM5 project. Last year I did a weight scale system using a EA9 and now I am doing a different project using a CM5. What I did was take the EA9 project and import it to the CM5 software and saved it. Now I was able to copy objects from that project into my new one.
thanks...
I figured you could import EA9 into CM5.
So you are saying :
You are able to copy and paste objects between CM5 projects
Well not directly. What I did was open the older project and objects I needed I would copy the screen to the library. Then open the new project and import the screen and copy the desired objects then delete the screen once done.
In the programming software they reaaaaaly should have just let you use the mouse wheel button to pan around, like in an autocad drawing. Sequestering us to scroll bars and arrows is a thing of the past Automation Direct!
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
154
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
156
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
635
I'm using an Automation Direct GS20 VFD for the first time and I have a question for the Automation Direct gurus regarding the recommendation of a...
1,137
I've been looking at the Automation Direct PLCs off and on over the years, but most of my customers are Allen-Bradley almost exclusively and won't...
1,800
