Hi guys!
I'm working in Studio 5000 and have a bunch of armorstarts there (+- 40).
I need to set up parameters for each of them, mostly just same values, but it's inconvenient to set up manually one by one so I've created a routine where I can change in each armorstart tag (since values are same for each one).
Only issue I'm standing up right now is after changing the parameters from looping, I got changed User I/O as well (they were set up before as 3x Input and 2x Output), somehow it got overwritten even though I do not change it in my logic.
Do you know any reason why does it change when I only change the values of tags or any solution how can I change user I/O by using tags ?
Thank you !
Thank you !
