Android/IPAD HMI/PLC View
slpefanis
Jul 2014
Victoria
Hi All.
I'm looking for a lightweight application that i can install on a mobile device to show some information from a Rockwell PLC. I was looking for something like sweetwilliams, but the creater has taken ill and no loger supporting.
Would like to have something that doesn't require serve/client software, but at this stage happy to look at whats out there.
Cheers
http://www.idea-teknik.com/en/hmi_droid.html
Check this out. I haven't used it myself but I was looking into an application where we would use this to communicate with a Micro850 PLC via Modbus TCP.
No reason why it wouldn't work in theory.
If you had an AB ControlLogix or CompactLogix you would need to use the Rockwell sample code to add support for Modbus TCP or use a third party module from someone like ProSoft.
Does it have to be iOS or Android? A Windows tablet will open up a lot more options of software and the hardware will be lower in cost also.
Has anyone figured out a way to use an iPad with Rockwell's software. I could really see some advantages to having the portability of an iPad if...
39
12,056
Hello everyone, we need to use android tablets that simulate Rockwell's panel views (tablets will be replaced by hmi which are having very long...
3,519
What should be the easiest way to control and view data from a Rockwell PLC using an Android smartphone without using pc? Can you suggest softwares?
3,750
Hi. I have a click C0-11DRE-D plugged in to a dedicated WiFi router (without internet.) I'm struggling to get any bit / bool to display properly...
1,622
Hello everyone, I have few questions to ask. 1. what things (languages, protocols ) we need to learn to create a library like libnodave, moka7...
3,378
