AN-X2-AB-DHRIO Prosoft Bridging With DH+
eci
Mar 2024
Murung Raya
hello, I have a problem with my AN-X2-AB-DHRIO Prosoft module, I can't connect with the module because I lost a microSD card that has firmware and configuration files. Is there another option for connecting the module without a microSD card on it?
thank you guys.
You can use another SD card, the format must be FAT 16 or FAT 32, no restriction regarding size or speed.
Use anSD card reader to store files.
The card must be present while the gateway is running.
For firmware and configuration files check this link
Thank you @tarik1978 for your advice, but I can't find the required files on the attached link.
They kinda hide the files for that , I had to ask tech support for them and even then it was a discussion and they had to post them on a fileshare.
I have the files but they are too big to attach (16mB) because of all the options it has.
I also tried to reach tech support for these files but there's been no response until now. Could you kindly send these files to my email?
Here's my email: [email protected]
Thank you
I just checked the files its ok for me to download
Yes, i've downloaded all available files on that link as well. But i can't find the files shown by @TheWaterboy.
Since i lost the SD card, i lost the config file and the firmware as well. and i didn't find those files on the attached link
Contact technical support
as i said in this reply, i already tried reaching the tech support team, but there's no luck
Thank you
Hello, I am upgrading an old Panelview 1000e HMI that was programmed with Panelbuilder 1400e. I communicates to a SLC 5/04 through a remote I/O...
1,297
We have a remove PLC rack that is being used to collect data from older equipment via a 1756-DHRIO module. This module occasionally faults out...
429
I have a 1756-L81e v32 using a DHRIO v7.001 in RIO scanner Driving (7) 1771 ASB Modules @ 115k baud. The Racks RPI are set at 48msecs. This system...
912
Hey guys, We recently picked up a new customer that just finished a controls upgrade with some other systems integrator company. They upgraded to...
1,769
I am trying to send some datas from PLC-5 to control logix plc through 1756-DHRIO. When I go online to PLC-5, Message instruction gives error &...
3,388
