Allen Bradley Dataliner 20 question
Chip Maker
Apr 2011
SE Michigan
(Time to put on your parachute pants and jump into the Way-Back Machine...)
I've searched this forum and tried Google-ing for an answer without luck.
I've inherited several departments in our plant that use Dataliner 20 displays. There are a hand-full of these units that display 'EDIT?' instead of the normal operator messages.
I am trying to determine how these units got into the 'EDIT?' mode when they were already working (powered down in AUTORUN mode). Also, the battery test passes its self test upon power up.
I realize this is a legacy product but hoping this problem jostle's a memory or two of other forum members that may have run into this problem as well.
Thank you!
These manuals are still available on Rockwell's Literature Library:
DL20 OFFLINE PROGRAMMING MANUAL Relevance: 100.0% 2706-NP3 Programming Manual 2706-804 English April 1993 331KB
Dataliner DL40 Plus Message Displays Release Note Relevance: 38.7% 2706 Release Notes 41061-092-01(C) English January 1999 2775KB
DL20 SERIES G USER MANUAL Relevance: 38.7% 2706 User Manual 2706-814 English April 1993 618KB
Page: 1Showing 1 - 3 of 3
Hello everybody, I must upgrade a very old line by adding few new messages on three Dataliner DL40 Plus message displays. The bad part is that I...
6,545
I have an Allen Bradley DL-50(2706-F11J)and would like to program from a personal computer, I have connected with a serial cable (about 10ft). I...
5,998
Hi, I would like to find out how many messages that the Allen Bradley #2706-B41J16 can give. Any other information on it would also be appreciated
6,319
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
125
417
