Allen Bradley 1746-A7 slot chassis
fons04
Nov 2007
Quebec
69
Hi, I'm new on Allen Bradley PLC's and i'm in process to buy a 1746-A7 chassis with power supply 1746-P2.I've already a processor 5/02. If i buy one Input and one Output card, it will work? or i need All slots with cards and a End card? Thanks you!
It will work, you dont need all slots filled in an slc system rack and you dont need an end card.
Also, note that you will need RSLogix500 software (not cheap) to program the thing, along with RSLinx Lite (free).
Additionally, with a 5/02 (or 5/01) you will need a comunication method. The old way to talk to these things was with a PIC module, but there are aftermarket devices that will do the job for le$$.
If you plan to run the software on a WindowsXP SP3 machine, note that you may have problems with the PIC driver, but there is a workaround for it. Post back when you get to that point and we can help you get "online"
Good Luck!
Paul
Good Luck!
Paul
Here's another source for after market devices. (PIC)
note : you need a real serial port for this.
If not ( no serailport) a 1747-UIC (USB to DH485 converter) is your best bet.
http://www.plctrainer.net/PLCProgrammingCables.htm
OR ...
keep your eyes open for an SLC-5/03 or higher processor ... those have a built in serial port - so you won't have to worry about the dreaded "PIC" or "UIC" communication methods ... specifically, a simple "null modem" cable from Radio Shack will work ...
basic idea: sometimes you can pick up a processor cheaper than you can get the cables lined up ...
also ... if the SLC-5/03 (or higher) has an operating system higher than 300 (OS300 in the specs) then you should be able to work with floating point numbers ... most SLC-5/03's (and higher) that are available "used" will have this capability ... it will probably come in handy somewhere down the road ...
good luck with your project ...
It is possible to use a cable RJ45 (CPU) and rs232(PC) wiring correctly for receiving and sending? If not why? And Where can i procure Rslogix500 not from Rockwell Automation? What's menaning of "floating points numbers"? Thanks
The electrical properties for RS232 and the RS485 present at the CPU are different and require active electronic components for the conversion.
You may be able to purchase an older copy on EBay but most offers do not have the necessary activation. Your Allen Bradley distributor is the best source.
Floating point numbers break very small and very large numbers into two components, the significant digits (mantissa) and the offset of these significant digits from the decimal point (exponent) and store these two parts in a memory location (typically 32 bits). This allows for great dynamic range at the sacrifice of the number of significant digits. If this is still unclear or you only need to count a small number of items then this may not be important.
I have two output cards sitting next to each other in a rack: 1746-OW16 1746-OW16 (Octal) output 13 in the first card triggers a solenoid. When...
2,212
Wondering if anyone has seen this and possibly knows how to fix. We have an SLC 5/05 with an NI8 and an NI4 in slots 1 and 2 in the rack. Both...
3,500
Hi All, Just a quick question, this is the first time I've had to use a 1746-ITB16 fast sink card do I need to use any special code in the...
4,262
Hi, how can i configure 1746-NI16I class3 analog input module? the needs are: 4-20 mA input Engineering unit data format i have read...
5,585
hi i need help in this problem unit slc 500 -1747-l542 give alarm -dh+01:u nable to communicate with remote station the unit allen -bradly conect...
1,855
