AdvancedHMI and FactoryTalk View SE on same computer
A_G
Jul 2014
MA
370
I would like to temporarily install AdvancedHMI on the same computer as FactoryTalk View SE. I am waiting for another contractor to finish the FTV SE HMI project but don't know when it will be ready. In the meantime I was thinking of using AdvancedHMI temporarily to let the customer see the runtime values of certain data points in the PLC. Does anyone see any issues with this? I do not want the AdvancedHMI installation to somehow interfere with/break the FTV SE installation. I have never used AdvancedHMI before so I don't have experince with this. Thanks in advance for any advice!
I see no reason why there would be a conflict between SE and Visual Studio. To be super safe, just develop your AHMI application on a different computer, then copy the debug folder with all of the compiled executables in it to the SE computer. That way, you don't have to install anything, just run the compiled project.
The programs should not interfere with each other, but what is the comm's method?
If it's serial using a COM port on the computer then only one program can use, and thus lock-up, the COM port which would then give the other program a communication fault
If it's Ethernet then multiple programs can be used at the same time
Not sure about the old KTX and DH+ cards ability for multi use
Great point.
Hi all, just wanna ask if anyone has used an M221 controller and successfully connected to AdvancedHMI
1,323
MessageDisplayByValue question is there a way to embed a tag value in the messages of the MessageDisplayByValue function ??? Similar to what is...
2,850
Hi All I have been switching between 2017 and 2019, all depending on which one i found more stable, at the moment I use 2019 I was just...
1,487
I tried to use AdvancedHMI as a Modubius Client and it does poll the data from a Modbus server. But I am unable to use AdvancedHMI as a server...
3,061
I am trying to open a MySql database within AdvancedHMI. I have added a button to show a connection, but It is coming back with the error: Client...
23
29,565
