Advanced Control - Electrohydraulics drive engine research
Apr 2002
No income tax, no capital gains tax. Freedom!
8,391
Last year at about this time I got a call from Sandia Labs. They had problems controlling a diesel fuel injection system. I was contracted to do a simulation to figure out what was wrong with their system and provide information that would help them setup their system in the future. I did a simulation for the diesel fuel injection system. It had to compress fuel from about 150 psi to as high as 43,000 psi. The high pressures were a new one for me. There were two diaphragm pumps that are use hydraulic cylinders to pump fuel using a 1/8 piston. This allows intensification of the pressure. I used cascaded controls. The outer loop controlled the pressure and the inner loop controlled the rate at which the two cylinders make the pumps cycle back and forth.
I found a lot of problems with the hydraulic design. I could have designed the system to reduce the pressure ripple to almost nothing but they already had the equipment. I determined they had to scale back the volume of diesel fuel they could expect to pump at 43,000 psi and then went on to make it work with what they got. It took about 14-15 hours to do the simulation but it worked well. The value I predicted were close enough where they had no trouble getting the system to work.
One of the things that was new is that the fuel would compress by 30% while it was pressurized to the injection pressure. This means the pump didn't pump anything at all for the first 30% of the stroke until the fuel pressure allow the fuel to go through the check valve. I think the original designer didn't take this into account. It is obvious to me the hydraulic designer didn't simulate the system.
http://machinedesign.com/hydraulics/electrohydraulics-drives-engine-research
The purpose of posting this is that one CAN simulate systems and predict performance values and PID parameters pretty closely even if the application looks pretty complicated and is non-linear.
Very impressive! Never having worked in high speed processes like that I can only say "Wow". Just getting transducers to respond fast enough must have been a challenge.
I thought the remark about hydraulic oil vis-a-vis compressibility was interesting. They indicate 0.5% per 1,000 psi, and at 40,000 psi that would still be 20% volume change. That would certainly be enough to mess with you if you considered the fluid incompressible!
This video shows the things I think about on page 1. I use Laplace transforms a lot. Laplace transforms allow one to express differential...
1,819
Instead of this info getting lost in another thread I will start a new thread. For those that don't know you can search for Advanced Control on...
2,662
sampling data. I will probably use this in a magazine article.
18
8,437
This topic deserved to be a separate thread with and Advanced Control header. The first video was made from videos a couple of years back. You...
1,543
Hello dear experts! I use WinCC Advanced Runtime V15 as a HMI for the process. I grab values from AB Micro 850 PLC via Modbus TCP. On the HMI...
2,419
