ACS355 max. speed?
11.04 and 11.05 set the max/min for Ref1 when it is configured as MOP or Floating Point in 11.03, as well as the analog inputs if they are selected.
In the less likely case that MOP is being used as Speed Reference 2, then the max/min is selected by 11.07 and 11.08 which also deals with the analog inputs when they are selected in 11.06
I'm sorry about the delay,
The motor work well but still have to set Parameters 1105 & 2008 to 120 Hz to get a high speed.
See my PDF files with all parameters.
See also the Motor picture
  • Cnf_FU_ABB_1.pdf
Thanks for your help.
I'm not a guru with high voltage motor.
But this simple motor is a 220V or 400V.
In my case, I use the 400v mode. See picture.
I tried to set the parameter 9908 to 3600, but no speed change!
I have to setup the 1105 and 2008 to about 120Hz to get the max. speed! I modified 3 machines with the same result.
Regards
Otto
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
153
how to wire a jog push button to unit and switch from run to jog mode
1,877
Currently waiting for Schneider Customer Support...:D ... meanwhile: Brand new ABB ACS355 with FPBA-01 Profibus DP adapter connected to a six...
7,741
I have two ACS355 drives (240V, 1HP) each connected to a Marathon Black Max 1HP motor. In both cases, very shortly after I start the drives...
28
7,512
hi! couple off months i instal this drive in a machine with a motor 15hp. the user goes up and down the spead with the cursors now he says that he...
1,379
