AB PLC 2.0 and AB PLC 3.5-10 with Plantpax
lalas
May 2011
canada
Hello All
We have 3rd party vendors that run on older versions of PLC (Plc2.0) while we run the main system using plantpax and PLC 3.5-10. Plantpx 3.5 has features such as controller alarming. It was suggested that we upgrade the 3rd party vendor PLC to plc 3.5-10 to match the plantpax PLC. I am not fully convinced with that and maybe we can bring in the PVs ,AI,DI,..etc through an add on instruction. My question is, do we need to create add on instructions at the sources (3rd party vendor) or in Plantpax. We will use factory gateway to connect both systems. The concern is the HMI objects in Plantpax will not be compatible with the PLC 2.0 (new set of HMI objects need to be created).
What would be a good way to bring in the values and have as such a standard HMI object in plant pax?
Do we need to develop add on instructions on the PLC 2.0 only or PLC 2.0 and PLc 3.5 or only plc 3.5?
Is there something similar to Quick builder from Honeywell that connects Honeywell to non-Honeywell systems.?
I hope I captured the theme of the issue at hand and would appreciate any input.
Hi folks, I'm after running into an annoying issue that I'm hoping you can help with. We've just started commissioning our first FTView project...
2,181
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
61
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
43
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
82
