AB Led lamp wont turn off when PLC output go's off
A triac output with no load will have voltage present at the terminal even with it off. This is due to the slight leakage current. When a load is connected to the terminal correctly then the voltage will drop to near zero. If the Nastybitofcode has 118V at the terminal with a solenoid connected then something is not wired right. Removing the neutral from the coil would cause that. Perhaps the neutral hooked to the coil is not at the same potential as the neutral in the PLC cabinet. If there is a high resistance return path to the PLC panel neutral then a high voltage would be sensed by a meter at the terminal with the output off.
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
153
hello I have 7cp476 cpu why can led always open and No connection
153
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
128
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
60
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
289
