1734-AENTR: is it possible to convert from A to C?
RetiQlum
Feb 2017
Arkansas
30
Due to a lack of upkeep and understanding of my predecessors, I have a PLS71 that was running V16 of Logix. I need to swap out an AENT for an AENTR.
I am going to convert the PLC to version 32 of Logix. My AENTR is Class A. Can I upgrade that through ControlFLASH to class C? If so, precisely what file do I need to download from Rockwell? The ones I have tried aren't letting me change versions, let alone class.
What is your processor? PLS71 doesn't match any AB processor that I'm aware of - the closest thing I can imagine is a 1756-L71, but I don't believe it could be one of those as they only support version 20 firmware at the earliest, from my recollection. I don't know of any processor that supports v16, that also supports anything higher than v20, so I'm not sure what processor you have that could be flashed from v16 to v32.
All that said, it probably doesn't matter. The more important question is, why do you want to flash from series A to series C on the 1734-AENTR? Unless you specifically need some features of series C that are not available on series A - and to my knowledge there generally aren't any - you can define it as whatever series you like, make sure that "compatible module" is selected under electronic keying (which it is by default) and the system will work with just about any series.
To answer the question you actually asked - no, I don't believe you can update a module from Series A to Series C. The series, as far as I'm aware, represents a hardware version - a series C is physically built differently at the hardware level. You can flash the firmware using controlFlash - though there are limitations on which firmware versions are available, based on which hardware version (Series A/B/C) you have. This technote (techconnect required) goes through the different firmware compatibilities for the different series, and has instructions on how to locate and flash the firmware.
Correct on across series flashing...
OP probably meant L71S. It can be flashed to ver 34. But it wouldn't be at 17....went down to 20. An L6x series would be versions prior to 20.
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
405
Hello all. I have a remote that uses a 1734-AENTR series C. We had to change it to a new one and, after adjusting the IP and number of slots...
595
The issue we have is that the IT2I thermocouple card and the RTD temperature sensor card connected through a point IO AENTR is constantly trying...
557
Hi guys, I have just recently purchased a 1734-AENTR module so that I could learn how to configure it through LogixDesigner and establish comms...
326
Hi there! I've been looking for some fault codes table for the 1734-AENTR adapters, since I'd like to show a message in HMI with some...
599
