FTView v.12 creating .mer v.5
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all, I have FTView Studio v.12 and I have a PV+1000 that has v.5 FTView ME FW. When I create my .mer the earliest option it gives me is to save it as v.6. I went to AB to see if I could load a later FW version to my PV+ however, it shows that the latest FW available for this HMI is what is loaded in it...v.5. Am I screwed or what? Thanks.
From what I remember, they removed the ability to make v5 runtimes from v12. Your only option is to install an older version of FactoryTalk.
The original Panelview Plus line firmware cannot be upgraded beyond v5.
As a separate issue, v12 Studio initially dropped support for creating v5 .mer files. According to this technote you can patch it to allow v5 and v5.1 file creation.
Unfortunately, it doesn't sound like they'll be creating the same path for v13.
i'll have to check this out.
I have a main VM with the most up to date version of FT view studio
and my "older" VM uses version 11, which allows me to make runtimes down to 5.... and then of course for the oddballs, a vm with a version 7 or 8, so the dinosaurs can get service without needing to update firmware if needed.
I created a Windows XP VM with Factorytalk View V9, Panelbuilder32, and other legacy software that is still occasionally needed.
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
41
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
63
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
185
Hello Experts, I am trying to create a SINE Wave generator and i cannot seem to make it smoother. I have done this before but i forgot the exact...
239
Is there a simple way (VBA or macro language) to acknowledge ONLY the most recent alarm? I upgraded recently all the way from RSVIEW 32 7.60 to...
644
