Powerflex 700 Losing Ready Status at the beginning of shift.
thezach222
Sep 2017
Southern Pines, NC
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just stops. No faults. Just "stopped". In the PLC program you can see it loses it's Drive status "Ready" bit. It only goes off momentarily, and comes right back, but the motor stops because of this. Has anyone seen this before?
You could try reading P932. It shows the source of the last "stop". Maybe that will give you a direction to go.
Rockwell Automation Publication 750-PM001O-EN-P, page 161.
I've found factory wiring on these that was improperly terminated and until you actually pull the wires from the IO to reland them you couldn't tell. It felt solid but was actually underneath of the clamp on not inside of it.
Hoping to catch a seasoned guru's attention on this thread who knows these drives. We have 3 PowerFlex 700s controlling fan motors in a cooling...
28
9,777
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
146
Can someone with Drive Executive please save me a printout of the parameters for this drive in this file. I'm in a bind and would greatly...
368
Hello all, I was forced to replace a Powerflex 700 to a Powerflex 70 due to what is available. The digital input parameters (361-366) have a...
491
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,198
