Micro850 + Sensor: 1 Axis can not move in negative direction when working together with sensor
vhs
Apr 2024
Indonesia
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot.
I use MC_MoveRelative to control the three axes of the arm robot. In my ladder program, when I connect the sensor to the MC_MoveRelative function blocks, all three axes of the arm robot able to move in the desired distance, however one of the axes, which is the lowest level of the arm robot, could not move in negative direction, it could only move in positive direction. But, this axis could move in negative direction when the sensor has no connections with its MC_MoveRelative function block.
I have checked all the wiring connections and the program itself, and found nothing is odd. I have tried many ways to fix this and ended up in the same situation. Do you have any idea what caused this problem?
n.b.:
_IO_EM_DI_00 is the sensor and _IO_EM_DO_09 is an electromagnet (the electromagnet works just fine, no issue)
Hi, I want to use an ultrasonic sensor with Micro850 PLC. Is there any cheap sensors that I can use for distance measurement?
2,214
HI everyone! I am trying to use a Micro850 to control a SureStep (Leadshine) Stepper drive (DM805-AI) from Automationdirect. I have no trouble...
186
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
313
I'm using a Micro850 with a Panelview 800, programming in CCW. We'd like the customer to be able to schedule the system to startup at a certain...
140
Currently a student, so somewhat new to this. But working with an AB 2080-LC50-24QWB, CCW version 21.01.00. CCW will connect okay to the Micro850...
316
