Melservo J5 by HMI control without PLC
dearannie21
Aug 2017
Illinois
I'm thinking about using commands for Melservo J5 controller via HMI without PLC.
Have you guys done this kind of control configuration for Melservo?
if anyone knows or familiar of this, please share our knowledge like communication methods, command methods (start, stop, alarm, and so on)
Thanks,
It is possible, but I do not advise you to do it. J5 is extremely fast, and HMI is always on order of several magnitudes slower. If your HMI is sufficient for motion control, than most likely you do not need servo, but VFD with closed loop would do a job. There are also lot of safety issues in this kind of setup.
My application will be simple as motor start and stop for brush.
What communication methods do you recommend to control by HMI without PLC?
Hello everybody. I encountered a problem - I don’t know how to update the firmware on the Mitsu MR-J5-40G-N1 (ethercat) servo amplifier. My...
408
I have 2 drives of MR-SA202 on one of our cylindrical grinders. The machine was relocated and re wired at the new place. The problem is that the...
1,734
Does anyone where i can download the manual for Mitsubishi Melservo Model" MR-C10A1?? Thank you! Regards sttchui
3,588
How are you guys? I'm Back.. :) Can someone help me regarding my Mitsubishi Melservo-SA type: MR-SA358R.. Im having a hard time looking for...
4,430
Hello, We are 2 students from Belgium and we have a problem with a servo system in a factory where we are doing a project. It works with a force...
3,547
