how to save controllogix project to smaller size file
I think there are another way to save PLC program as .ACD file, but smaller than normall saved, because I see somebody did it, but I forgot how to do it.
You may (or may not) find this thread interesting:
http://www.plctalk.net/qanda/showthread.php?t=54959
Suffice it to say that since its a structured storage file it may be much larger than it really needs to be. You can do as bguinn says and save it in an L5K format but that might be a pain to work with. You could try saving as an L5K and then importing the L5K and saving as a new ACD file; the new ACD file might be smaller since it doesn't have any old stuff left over in the structured storage file - I haven't tried it though.
Personally, unless you're facing problems transporting the file, I wouldn't worry about it.
I try "Compact" function twice, but it takes too long, and RSlogix5000 become unresponsed.
It is what it usually does with large files. You must have faith... We usually start the function before we leave work. It is usually done when we come back next morning.
just trying doing a "File/Save As" operation - but give the file a new (different) name ... if that works OK, you can always use Microsoft Windows to "rename" the file later - even back to the original name if you want to keep things straight ...
Forgot my dongle at work, would someone please save as a l5k file for me. Have to do some importing of tags for rsview 32. Thanks.
1,483
Hi; First of all, I am sorry that my post is not relevant with this forum. I have recently purchased Samsung cell phone. I have alreay saved...
84
Hello! I have a datablock in a PLC witch contains about 700 variables. I must save this data once a day on a Windows PC in a XML or CSV file. Eg...
499
Hello Folks! I have an issue and its very often but in this case i applied all the tricks and tips that i always do in similiar issues but in this...
785
I'm a bit stuck again... See the redacted picture. At the moment, pressing F7 saves the "live" laser measurement into the boxes indicated by the...
1,106
