FactoryTalk View SE - Can't select specific times on trend
ChBE_GT_2014
Apr 2024
Georgia
Hello,
We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where we can no longer select any time and grab the value for the tag that was recorded. The graph will only go to a select number of random times displayed. For example, I want to see the value at 4:40 pm, but when I click at that point on the graph it displays what I assume to be the next available data point at 4:51. Before the transition if we repeated the exercise we would have the value at 4:40 pm show up.
We have multiple trends, and one trend seems to function as normal, but a majority do not. We did not do any coding changes during the server upgrade so any refresh/record values should still be their original values. Our data is logged through a SQL database I believe.
Is there a way to fix our trends to allow operators to select any time displayed and grab the value of the tag?
What exactly does upgrade control server mean? Upgrade the PC hardware, the OS, the FTSE version? What's the architecture? Distributed, standalone, etc?
I believe it was an upgrade to the OS as well as FTSE version (we are currently in V12.00). I'm not too familiar with architecture or if it is distributed/standalone unfortunately.
This issue happens occasionally but is getting annoying...I cant click what I said in the title randomly. Sometimes it works sometimes it doesnt...
1,607
Good Afternoon , I created a small FactoryTalk View application , and created a runtime. I want to download it to a Panelview Plus 6 700 ...
4,483
I have a control list selector with 50 states. My problem is that it's inconvenient to go through the list by ramping and then landing on the...
8,477
Has anyone found information on using the variable message file? I keep looking for documentation on how to implement the message file name as a...
41
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
221
