Air Conditioning for HMI
cm-nonwov
Oct 2023
Massachusetts, MA
Hello All,
I've been tasked with automating a flatbed press that runs with some pretty extreme temperatures. I've been told it can run close to 120F at the current (relay controlled) control panel. I am going to mount the PLC in a room that is very close by that has AC, and the drives are getting mounted across the room in a fan cooled cabinet. They want to mount the HMI (I want to use a cmt3072xht from Weintek) right were the old controls were. I'm concerned that it won't last long over there without some sort of cooling. I'm not sure how helpful mounting a fan to the side of it's 14x"18"x6" enclosure would be, given the ambient temperatures.
A few years before I got here, they had an outside company come in and do an estimate on the same job, and they list using a similar HMI too, so I know that at least one other entity was going to try this setup.
Any ideas on how to cool the inside of that box? Any one know of a tiny air conditioner?
There are air powered vortex coolers that will do the job, but they can be noisy and use compressed air. Enclosure manufacturers usually have AC units as an option.
Vortex coolers are simple to install, but be sure the hose is clamped tight and secured in the panel. I once had one blow off and condensation from the air system dumped right into the top of a Compactlogix.
I have been looking for justification to try one of these thermoelectric coolers, but haven't had the need yet:
Ding Ding Ding! We have a winner! I'm gonna give that thermoelectric cooler a go because I have such a small space to cool. Maths out about right *crosses fingers*
Hello: Hello, does anyone knows air conditioning units that can be monitored and controlled by a PLC or SCADA, on a Modbus network or another? A...
2,582
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
381
I Am looking to get ahold of the modbus map for an air compressor. I HAve emailed the vendor as well, just wondering if any of my friends here...
125
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
151
The web abounds with companies claiming they can repair HMIs and other industrial electronics. I am looking for recommendations for companies...
1,329
