WinCC <---> Excel communication
swapnil.naik
Mar 2013
Thane
45
Hello,
I want to store data in WinCC into Excel, Like daily hour wise report or monthly report.
I have never attempted this stuff can anybody guide me or provide any documentation. Also help on data logging in SQL will also be great help.
Hello Swapnil Naik
1. If you only want to acquire data "online" (tags directly from WinCC) and store their values in Excel database, check the file OPC.pfd located on the computer where WinCC is installed (path drive:\Program Files\Siemens\WinCC\Documents\english\). The chapter "7.4.4 WinCC - Microsoft Excel Connection" gives an example about that.
2. If you want to access historical data (tags, alarms) from archives, you need to install WinCC/Connectivity Pack (with license) option of WinCC.
Regards,
teckhno
Thanks Techno !
I have successfully generated report in Excel which creates Hourly Report of attached tags and creates new excel sheet with File name & Hr & date.
If any one requires code kindly contact me !!
Hello Swapnil Naik, I am looking to do exactly the same thing you did and, although I have a script that export the data, it is based on an event and not on a cyclical count. Would you please post the code? Many thanks!
Regards,
BKC1
Easy with vb scripts
Set objExcel = CreateObject("Excel.Application")
Set objWorkbook = objExcel.Workbooks.Open("C:\reports\new report.xls")
you just need excel in your system...
Hello ScrapperPt,thanks for your answer but my problem is how to execute the script periodically.
Hello Swapnil Naik I will send you a pm with my email, many thanks!
Regards
Hi guys, Has anybody got any example about the data communication beetween Protool or WinCC and Excel? Thank you in advance
5,085
Hi I have a Client who wises to log 6 analouge values every hour and then generate an excel / CSV file every week with the data for that week. So...
389
hi dear experts. I'm an industrial engineer working with wincc explorer rt 7.3 I need to send some weights to other software. is it possible to...
159
hello guys... i m looking for example how to send excel recepi to wincc flexiable (HMI) and when click particular formula it will start using the...
1,987
Hello everyone. I'm trying to export data to excel from Wincc. My code is global action that executed every second that create excel filer per...
6,126
