1747 Open Controller
JJ_PLC
Apr 2013
Houston
Looking for help on a Legacy project. Need support on the old Rockwell / Allen Bradley 1747-OC open controller. Apparently the product was introduced in the 90's and discontinued in 2000. This PLC/PC based system has a DOS operating system and is able to be programmed via third party devices (via APIs). Third part products for programming this system included "Controlware" (which could be programmed in a ISAgraf development environment) or SoflLogix 5 as a runtime system with RS Logix 5.
I’m looking for hardware and software for this series to support this legacy project. Since Rockwell isn’t supporting this anymore... it is hard to find parts/software.
Does anyone know where I might be able to find hardware for this system and/or a old copy of "controlware" or Softlogix 5 to support the programming of this hardware?
Any information would be helpful. The need is pretty urgent.
Thanks in advanced.
:confused:
The 1747-OC was probably built by Online Development for RA.
Those guys will be your best chance for support on that product.
RSLogix 5 is still a supported product; SoftLogix 5 isn't popular, but it's still around. ControlWare I've never touched.
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
98
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
559
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
409
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,630
Hi Newbie here :yeah: Can one of you experts help me with setting up a simple BTR and BTW to just test 4 analogue inputs 4-20ma (1974-if4i)...
1,004
