escoplcguy
Hey All,
So I was just informed that i need to tell the PLC information about a block EX: size, strength, weight. We have a system called Movex which is our ERP/Inventory system.....personally i dont know much about the system other than the data resides in a MS SQL server and we use ODBC connection to connect to the database. My questions are what more information do i need to know from the IT guys about our system, how can i use an in-line barcode scanner to scan the barcode as it enters a convayor to tell the PLC information about the block, and what type of instruction will i be using???
currently on the machine we have a Micrologix 1100, it is not hooked up to ethernet...in the future we will be upgrading to control logix...
Our process would be as follows.....
a block that needs to be cut down to a smaller size enter convayor.
block gets scanned in; report to PLC: block ID, size to be cut, and strength of block.
block moves to a strength testing machine and gets tested if passed moves to next area of convayor....block gets cut to size.....block moves to block height measuring machine nd gets tested......if passed block gets sent to shipping. PLC reports to ERP/Inventory system of size and strength and passed or failed.
thank you
thank you
