WinCC Flexible and Melsec Q Ethernet
desuhardi
Oct 2005
Indonesia
46
Hello,
I need information about using wincc flexible with melsec-q ethernet, is it possible ?
Becuase when I saw wincc flexible 2008, it don't have connection with melsec-q ethernet.
The only one ethernet connection is modicon modbus tcp/ip and must select type of cpu.
Iv'e never used win cc in it's modern form but if it can use opc or dde then there are a number of I/O servers you could use, one of the best I have come across is Kepserver, if this is the way you wish to go then you only need to set up a udp connection in the melsec then set up the server it's quite simple using the opc.
Not sure if siemens supply drivers for other plc manufacturers.
Thanks Parky for info.
I've seen Kepserver and its price in their web, but no information about how many tags can handle with kepserver.
Do you have information about this?
WinCC supports OPC for sure
Well the last project I did had over 15,000 tags so I'm sure it will handle a lot more never really thought about it.
You can download the full version from kepware it runs for 2 hours at a time without a license so you could test it & even get it all up & running before getting the licence.
I must admit after using it a number of times I'm very impressed, never seems to fall over & easy to use.
You can either configure the tags in the kepserver or in the win cc, all you need in kep is a channel & device set up with the communication protocol there is a good help file for each plc etc.
if you configure a few dummy tags then export them as comma delimited file, open it with excel then use the layout to import or configure the tags then import them into kepserver (useful if you have the tags exported from a plc file or scada.
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
294
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
116
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
765
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,605
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,485
