Peter Nachtwey
Your system is non-linear because adding one liter of hot water will have a greater affect when the level is low than when the level is high. If there is no water in the mixing tank the response will be very fast. Honestly, I don't think it makes much difference to the tuning because the water level should always be about 1 meter unless the demand is greater than what the pumps can supply. Pandiani wants to solve your problem using LQR so he needs to have a linear system. I linearized the system a lot with in the conversion from level and temperature to hot and cold control outputs. I didn't do it perfectly. I think with a little effort Pandiani can find a better better but more complicated formula.taz3m said:Im sure you are right Keith, i should listen to their advice carefully,...
Thanks for the manual it will be of great help im sure...
peter to tell you the truth, i have take a look to your pdf.. hmmm, nice... hope you understand me..
I will try to understand it, but i will have a lot of questions..
Firstly how do we know that a system is linear or non-linear..???
We shall see once if linearizing makes a difference once we get the simulator working.surely the LInear one is more easy to work with, since you are trying to linearize the system.
Taz3m, download Scilab from www.scilab.org and install it.
http://www.scilab.org/
It is this software that I am going to use for the simulation.
