B&r plc m264
I haven't ever actually worked with panelware and don't know anything about them, but if the HMI program is stored on some kind of memory card, you should be able to just buy a replacement HMI on ebay and hope that it's a hardware issue and not a corrupt memory card issue.
Since you're talking about a PLC that has been obsolete for multiple decades, you might want to look to look to the future. If the OEM is still in business, they can probably retrofit the machine with a C70 and some X20. If not and you have a drawing set, any B&R integrator should be able to pull it off.
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
109
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
75
68
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
495
