Inductive Automation Ignition Fanless PC Hardware
GTUnit
Oct 2009
Orange, CA
401
Can someone please recommend some fanless PC models that are proven to host Ignition Gateway/software and MySQL well with no hiccups?
I don't need a monitor/panelPC. Just the PC brick to put inside a panel.
I did a small headless Ignition/MySQL system on a Fit-PC2, which had an Atom CPU and 2 GB of RAM. Ran fine.
I have one running now on an Atom "mini server" from SuperMicro.
Advantech always comes up as a good vendor for this sort of thing. Pick anything that's not their lowest-end model and go for it.
We use B&R industrial PCs and are really happy with them.
Be sure that your CPU architecture is supported by the OS you intend to run, and let 'er rip.
Bit of a grave dig here guys, but still on topic.
Trying to spec up some hardware for my first Ignition project. Will have a main server for the Ignition gateway, and full desktop PC's running some clients. But I also need to have a couple of HMI's around the place running Ignition clients as well.
Anyone have an opinion on how well it will run on an Advantech TPC-1051WP?
Specs:
Intel Atom E3827 Dual Core 1.75GHz
4GB RAM
128GB SSD
W7 or W10 Embedded OS.
Appreciate any advice!
C6015 from beckhoff is a pretty package, and they know their stuff when it coms to industrial windows PCs.
Their only standard option though is a 60GB SDD upgrade, not sure if you can ask them to put a 120 in there for you. Has an "accessible SSD slot".
Specs:
4GB RAM
128GB SSD
Just to clarify, are you planning these as clients to the main server, or will these be standalone (Ignition Edge-ish) installs?
If just a client, what you have is fine, otherwise, I'd consider bumping the RAM to 8GB
Actually, I recommend the RAM upgrade either way, just for a touch of future-proofing... :)
Just as a display client to the main Ignition gateway server.
Thanks for the advice!
Hello guys, Sorry for that, I decided not to wast yours and my time. Thanks
2,972
Inductive Automation Ignition unable to trend small numbers . Trending stops working below 5e -9 . 5e -9 = 0.000000005 . We are operating...
3,092
All, I know this type of question has been asked (and sometimes answered) ad infinitum but after looking I'm still stuck and could use some help...
19
6,285
Hello All, I am looking for a way to get the data/information from METASYS BAS of Johnson Controls. I would like to get this data into Inductive...
2,370
So I'm exploring the different options within Ignition and I can't find a PID Controller anywhere in the library objects. Am I missing something...
2,119
