s7 300 and 400 master slaving
moazzim
Apr 2007
Dera Ghazi Khan
i want use s7 300 in slave coniguration with s7 400 as a master via cp cp master slaving i am using 342-5 cp and i have to use dp port of s7 300 as a master for furthe profibus drives and et 200
can any one give me idea how i call siemens fc or sfc in masters program and in slave programe
to tranfer data b/w cp's of mater and slave
Hello moazzim;
The following link will take you to a Siemens support webpage that will describe configurations for setting a CP342-5 as slave to a S7-400:
http://support.automation.siemens.com/WW/llisapi.dll?query=S7-400+master+CP342-5+slave&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=0&nodeid0=4000024
and look at the third link proposed.
Since you are asking quite a few questions on Siemens PLCs for the past few days, you should take a few minutes to study the Siemens support website. The Search facility is one of the best in the business; for example, look at what a search on "CP342-5 slave" has come up with. Try looking for help on any other subject where you need help (use the left colum to select only manuals, or FAQs, depending on what you need).
Hope this helps,
Daniel Chartier
P.S. By the way, could you have registered under an assumed flag? You seem to be from Pakistan (at least you state you are from a Pakistanese city) but you display a flag from Central America?
dsg file for cp342-5
one problme more that i am facing that is i have 342-5 firm version 5.0 in simatic but in phyisicali have version 5.4 i try to get dgs for that from sight but at this firm version that was unable for download if some one has dsg for cp 342-5 firm version 5.4 kindly provide me thanks
thanks daneil
do u know about master master coupling
for transfering data from one master to an other
my practice is to use wincc globel addressing
one way is through mpi with the help of globel table in simatic
but i lesson about some simatic functions that r used for golbel tranfering of data in ur pls net work
do help me in this matter
Hello maozzim;
I usually use a DP-DP coupler for this, very easy to setup as a slave to each master (it has 2 DP slave interfaces, one for each bus); 244 bytes IN/OUT, generally enopugh for data exchanges between masters.
On other projects, I have used FDL exchanges between masters, over Profibus-DP.
Search on this forum, many threads have discussed the issue.
Search for FDL exchanges on Siemens' website.
Hope this helps,
Daniel Chartier
thanks but
you r right
but if we have two different networks then that is good practice to use dp dp coupler and i am using it
but i want to exchange data from one s7 400 to other s7 400 master at the same network that of profibus in this case i think the use of dp couplet for exchanging data is not a good practice and costly
because i a have five master in my one net work and i am deal with two networks having slaves 8nos for each if i used dpdpcoupler for each master its very castly
do u have any idea
With S7-400, you can simply configure a "connection" between CPUs in NetPro.
Then you can configure PUT/GET blocks with the connection IDs from NetPro.
In that way you can exchange data between S7-400 masters in the same Profibus network.
edit: I just read from the 1st post that a CP342-5 is mentioned, which means S7-300 and not S7-400.
With a CP342-5 you can also configure PUT/GET data exchange.
But I am confused now. What do you really have ? What do you want to achieve ?
simply lets say i have 2 masters s7 400 and pc they r connected via profibuss with cp 5611 for pc and cp443-5 basic for s7 400
and i have slave system via cp342-5 for 315-2dp i am able to comunicate master slaving between dp of 400 and cp 342-5
the dp port of 315 i used in my master system too bye that i can view online and make achange in slave too from my engineering station i am taking the data from one slave of one master in an other master but i am not able to transfer data between cp of master plcs of 400
do u understand my problme now
moazzim.
Please consider that you get this help for free from people that may have other things to do.
So, please state EVERYTHING relevant about the installation, and EXACTLY what you want to achieve.
You are providing the information in little drips (in your last post you popped the information that there is also a CP443-5), and I dont know exactly what you want to achieve. "Exchange data" is not enough.
Hello guys;
Jesper, when you are right, you are dead right.
Moazzim, CPUs and CPs from Siemens have different capabilities and communications blocks available, so to help you we must have a complete view of the hardware you wish to connect. Could you draw a schematic (or show the contents of Netpro if this exists already in a single project?)of the networks you need to interconnect?
Second, the following link will show you different aspects of the Put/Get communication blocks (capabilities, limits, programming) that might be of help to you:
http://support.automation.siemens.com/WW/llisapi.dll?query=Profibus+Put%2FGet&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=&nodeid4=20229805
Look at documents 21 to 30 (third page) of the link.
Hope this helps,
Daniel Chartier
brother
i just want to tranfer data from cp443-5 basic to another cp 443-5 basic of two different plcs in a same network
thats called master master coupling i want to use the i/o of one master plc in another master plc on the network via cp 443-5
i think i write clear
sorry if any one confused
Hello moazzim;
The Put/Get functions should work for you then; see the previous link.
But:
First you will have to transfer the I/O information to a DB (Source)area, for example, then PUT that Source data into a Destination area in the other CPU.
Hope this helps,
Daniel Chartier
can u tell me about systm function or siemens library fn that i have to use to transfere these data blocks from one plc to other just like fc 14 and 15 , sfc 14 and 15 that i used in dp (master)cp slave coupling
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
179
Hi guys, I'm having problems converting WinAC (WinLC RTF F application) to S7 300 project based on CPU 319F-3PN or S7 400/416F-3PN. The problem is...
615
Hello All I hope you are well and safe. I have a problem that I could use your appreciated input for: SW: SIMATIC MANAGER v5.5 SP3 HW1...
1,228
Hi What stage of its life cycle, S7-300/400 controllers are at now? In my existing unit, we are using these controller and in near futher there is...
7,064
